LabWindows/CVI
How to Change Modes(like MaxHold or FM Dev.) on E4440a (Spec.Analyzer ) remotely
I need to chande meauring modes while running my test procedure software using an E4440a spectrum analyser
specifically MODE - Measuring Receiver - FM Deviation
there exists no such mode changing commands on the driver how can i deal with it?
Thank you
Levent ;
(2,943 Views)
If you are using the agesa driver for the E4440a you might use the WriteInstrumentData function (Utility->Instrument I/O >WriteInstrumentData)  to send the GPIB command string for that mode to the device.
(2,934 Views)
