LabWindows/CVI
Different GUI font on systems with Asian Windows?
Accepted by NTi_Greg
The portion of the registry that you are modifying is used only for 64-bit programs. Are you running a 64-bit version of your program? If not, try editing the following location instead:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\National Instruments\CVI Run-Time Engine\cvirte
Message 11 of 12
(1,363 Views)
BINGO!
that did the trick.
Thanks a lot Luis,
Message 12 of 12
(1,352 Views)
