LabWindows/CVI
Disable Got Focus rectangle
Is there a way to disable the Got Focus rectangle associated with a control?  As an example, the gray rectangle within a button control, or the gray box surrounding a picture ring control.
(3,777 Views)
Accepted by hendra@ngms
I am not aware of a way to hide the focus highlight: as far as I know the only possible workaround remains the one suggested by Luis in this post.
(3,774 Views)
Thank you.  A little cludgy but it works fine.
(3,770 Views)
