LabWindows/CVI
Disabled control receiving events
If I have set the attribute ATTR_DIMMED to 1 (active) on a control i.e. disable (or grayed out) the control. Will the callback function that is set for that control, receive any events at all? I have done this on a textbox control and the callback function does not get called anymore (until ATTR_DIMMED  is set 0).
Christian G.
(3,698 Views)
A dimmed control does not receive any event, neither the EVENT_DISCARD.
As an alternative to dimming the control, you may consider to set it as an indicator instead, either in the editor or programmatically calling SetCtrlAttribute (..., ..., ATTR_CTRL_MODE, VAL_INDICATOR);
(3,691 Views)
Thanks!
(3,689 Views)
