Discarding popup after a certain time automatically
I am creating a popup panel using installpopup and use GetUserEvent to get the event commit from the user. I also need to add an additional feature wherein, this popup panel if no event commit has occured should automatically be discarded after a specified timer interval.
I used a timer to get the time lapse, however as GetUserEvent takes control and waits for an event commit.. i am not able to discard the panel on the condition of the time elapsed for user to hve clicked on an event. How do i program this application.
with gratitude
vivek $
(2,945 Views)
Instead of using GetUserEvent, simply install the popup and use a loop and some global variables this way:
1. Set global variables to 0
2. Create a callback for the OK, QUIT or whichever button is in your UIR that concludes the panel; in the callback raise a flag (e.g. "OKbutton = 1")
3. In the timer callback raise another flag when time expires (e.g. "timeout = 1")
4. The routine will look as follows:
// preceding instruction up to the popup display
InstallPopup (panelHandle);
while (TRUE) {
ProcessSystemEvents (); // To permit detecting user interface events
if (OKbutton) {
// Set some flag to determine following code behaviour
break;
if (timeout) {
break;
RemovePopup (0);
// Your code follows here
This way your code should work the same way as using GetUserEvent but with the additional timeout feature.
Hope this helps
Roberto
(2,944 Views)
