08-18-2010 03:11 AM - edited 08-18-2010 03:12 AM
Hello.
I'm using a Keyence camera system to get images (8bit greyscale in uncompressed BMP format) from different objects.
After triggering the image capture I want to do several things with the image data:
- transfer it to the LabWindows/CVI PC (this is done with a serial USB connection to the camera system)
- display it to the user as a 8bit greyscale image
- pass the 8bit greyscale image into a third-party function that does some calculations with it (the third party software accepts a double array together with height and width as parameters, so I do have to convert the image data to double)
- save the image to disk
So far I've done this as a first try to get things working (I wanted to create the bitmap, copy it to the clipboard and then display it in Windows Paint):
int ProcessImage(void)
int hwError = 0; // error code
int bitmapID = 0; // bitmap ID
char cvBitmap[2000000] = {0}; // bitmap data aquired from the camera
int colorTable[256] = {0}; // color table for the bitmap
hwError = CVCameraGetBitmap(&cvBitmap[0]); // get the bitmap data from the camera
if(hwError != SUCCESS)
DebugPrintf("ProcessImage(): GetBitmap failed\n"); // error handling
return FAULT;
for(int i=0; i<256; i++) // fill the ColorTable for the bitmap
colorTable[i] = i;
hwError = NewBitmap(1600, 8, 1600, 1200, colorTable, cvBitmap, NULL, &bitmapID); // create new bitmap
hwError = ClipboardPutBitmap (int bitmapID); // copy bitmap data to clipboard
// DiscardBitmap(bitmapID); // delete bitmap
return hwError;
When i paste the image in Paint it just displays all black, so I think maybe it's something wrong with the color table?
I didn't manage to get a proper image, though. Maybe one of you can help me out there?
Thank you for your help.
Bernd
P.S. I'm using CVI 9.1
08-19-2010 04:30 AM
Hi Bernd,
maybe this will help you:
#include <utility.h>
#include <ansi_c.h>
#include <userint.h>
#include <cvirte.h>
static int gHeight;
static int gWidth;
static int bmpID;
int pixelDepth, rowBytes, *colorTable = NULL;
unsigned char *bits = NULL, *mask = NULL;
static int colorSize, bitsSize, maskSize;
int main (int argc, char *argv[])
if (InitCVIRTE (0, argv, 0) == 0)
return -1; /* out of memory */
GetBitmapFromFile ("c:\\Penguins.bmp", &bmpID);
GetBitmapInfo(bmpID, &colorSize, &bitsSize, &maskSize);
colorSize=256;
if (colorSize > 0)
colorTable = (int *)calloc(colorSize, sizeof(int));
bits = (unsigned char *)malloc(bitsSize);
if (maskSize > 0)
mask = (unsigned char *)malloc(maskSize);
GetBitmapData(bmpID, &rowBytes, &pixelDepth, &gWidth, &gHeight, colorTable, bits, mask);
colorTable[i] = 10000*i;
NewBitmap(rowBytes, 8, gWidth, gHeight, colorTable, bits, mask, &bmpID);
ClipboardPutBitmap (bmpID);
DiscardBitmap(bmpID);
return 0;
