LabWindows/CVI
Display of table values
Hi
I have a column in my table set to Numeric, the moment i insert a row, a 0 is bing displayed in the row at that column, i would like it to display nothing at all. Is this possible?
Cheers
AL
(3,050 Views)
If the default type for the cell is numeric, there is no way of hiding the "0". I can think of two different workaround to obtain this effect.
First, set the new cells as string to obtain an empty cell; you'll have to decide next how and when to change the cell type.
Another possibility is to set the text color to cell background color: again, you will need to change the text color in a certain moment.
(3,047 Views)
Hi Roberto,
thanks for the help, i'll set the box to string then convert it back.
cheers
AL
(3,032 Views)
