LabWindows/CVI
LW/DOS availability?
A client company has just given us a medical instrument and requested a quote to upgrade this device. The software was done in 1994 and used the MSDOS version of LabWindows. The client acquired the designs for this device a few years ago, but did not know enough to ask for the LW/DOS development tools. A redesign involving moving up to LabWindows/CVI would probably require more extensive FDA approvals, so it is beneficial if we can make these modifications under the older development tool system. Is there any way that we can procure a copy of LW/DOS so that we can work on upgrading this product?
(3,158 Views)
Hello Doug,
I would suggest contacting your sales representative about the availability of LabWindows for DOS. Also you can email the Sales force on the following website.
If this is not possible, you can easily convert your LabWindows for DOS source code, user interface and function panel.
More in depth information can be found in Chapter 12 of the Getting Started with LabWindows/CVI document.
Hope that helps.
Wendy L
LabWindows/CVI Developer Newsletter
(3,132 Views)
