LabWindows/CVI
Distribution Kit Error
Thanks for your time ..... and your ideas
1.- I went to your previous e-mail ...but I was not sure about the issue(what you want me to 'check')
    a.- The 'link' you sent me (?)  seems to deal with 'errors' during the DIST KIT's creation, but in my case I did not get any errors
        it stops because a module (device driver NOV 2008 )was not found
    b.- My CVI distribution kits 'builder' works OK with any other application I have tried , but these others applications
        are very simple (not using Dll.lib, etc)
2.-  So, if my CVI Rev 9.x is working OK and can create Distribution Kits with any other application, I am trying to
    find the possible root cause :  I guess is not the CVI environment
Could you clarify or explain what you need from me
Jose Olvera
Message 21 of 26
(2,583 Views)
I've copied the relevant part of the post I had linked:
Select the "Build>>Distributions>>Edit <name>..." menu item, make sure the tab has focus (dotted box should be around one of the tab labels), and press Ctrl+Shift+L.  This will cause a detailed debug log to be written to your temp directory (Documents and Settings\<username>\Local Settings\Temp\distBuildDbg.log).  Build your distribution.
When you are prompted for disks, try to insert what it asks for. Once you get to the point where you think you're stuck, close CVI down. Then find the debug log and post it here. It will contain details that will be useful in understanding your situation.
Mert A.
Message 22 of 26
(2,577 Views)
a.- quick : the error DLOG found
b.- LONG: the full DLOG  (How can a file be attached ?)
> *** Error: Internal error. (Error code -40)
> Product 'NI-DMM 2.4.6' depends on a product that cannot be found on the system. ID of missing product: 'NI-MXDF 1.2.0f0 for PharLap' - {BBC3E40F-E55F-469D-81F3-9963ECD350FB}
> Product 'NI-DMM 2.4.6' depends on a product that cannot be found on the system. ID of missing product: 'NI-MDBG 1.1.0f0 for PharLap' - {2146BD10-9FC7-44AA-89A3-9DDDA44525A8}
> Product 'NI-DAQmx 8.0' depends on a product that cannot be found on the system. ID of missing product: 'NI-MXDF 1.2.0f0 for PharLap' - {BBC3E40F-E55F-469D-81F3-9963ECD350FB}
> Product 'NI-DAQmx 8.0' depends on a product that cannot be found on the system. ID of missing product: 'NI-MDBG 1.1.0f0 for PharLap' - {2146BD10-9FC7-44AA-89A3-9DDDA44525A8}
> Product 'NI-DAQmx 8.0' depends on a product that cannot be found on the system. ID of missing product: 'NI-MRU 2.2.0f0 for PharLap' - {67E0FC79-6000-4365-BBF3-5800D1E7B6D6}
Error in MDF API function: _MDFProdPreview_AddProductDone
PartDependsWalker encountered an error processing the depends list.
> *** End Error Report
next is the FULL DLOG file
[BEGIN LOG]  Fri Jan 06 07:54:13 2006
    MDF modules:
        NIMdf.dll [MODULE NOT FOUND]
        MdfCommon.dll [2.0.1.81]
        NIMsiDistKit.dll [2.0.1.81]
        MetaBuilder.dll [2.0.1.81]
        NIUniquify.dll [2.0.1.81]
        xerces-c_2_5_0.dll [2.5.0.0]
    [LOG ON]  Fri Jan 06 07:56:02 2006
    [PRODLIST]  Fri Jan 06 07:56:02 2006
> Loading product deployment information
Loading MdfInfo: "C:\Program Files\National Instruments\Shared\MDF\Bin\MDFInfo.xml"
Loading manifests from: "C:\Program Files\National Instruments\Shared\MDF\Manifests\"
Loading PDF: "C:\Program Files\National Instruments\Shared\MDF\Manifests\NI MetaUninstaller {B1F27A23-B6D1-4397-BA2F-25F348DF135F}.xml"
Loading PDF: "C:\Program Files\National Instruments\Shared\MDF\Manifests\NI LabWindows_CVI 8.0 Run-Time Engine {E47A1A3A-FE2B-4D96-BBD2-6AA21E1EF816}.xml"
.... I cannot exceed from 10000 characters (as you know)
     is already satisified by Part: LVBroker.msi PC: {BCD6D492-DB6C-4582-8AE3-8EE9D4EAF74A}
  Processing dependency UC: {B0CAF85C-5484-4FCD-BF9D-20EAF483A913}
  Processing dependency UC: {AA71846B-4135-48CA-937D-BE42FC0BC692}
     is already satisified by Part: lv80runtime.msi PC: {A5D1EA23-CEE5-4B72-A0C3-8BCEDFC6F94C}
*** About to dump pretty-printed error messages to the UserLog
Jose Olvera
Message 23 of 26
(2,576 Views)
It looks like you have posted a very old log:
You may have made some mistake while following the log generation steps. I would recommend first deleting this file before you try creating the log again, just to make sure there aren't any mix ups.
To attach a file, right below the Post/Cancel buttons, you'll see a place you can enter Tags, then below that there is a link that says "Add Attachements".
Mert A.
Message 24 of 26
(2,565 Views)
I have found a working solution.... and I may close this issue
1.- I created a 'new' BUILD->EDIT session .....from scratch , only CVI run time was 'checked'
2.- The Build was done w/out errors , and did not asked me for any driver (CD/DVD,etc)
3.- I got the typical 'warning' that the apps. could fail (unless I had already installed such components)
4.- Since in my case these 'modules' were installed ...  I ran the setup.exe and looks OK
question: My rev 9.0.0 was installed (or purchased) on NOV 2008..... when is coming the next Rev ?
Thanks for all your time and great support
Jose Olvera
Message 25 of 26
(2,547 Views)
CVI 9.0.1 was recently released, and if you are on the SSP service plan, the disks should have been mailed to you. Besides that, I can't give any word on when the next release will be.
Mert A.
Message 26 of 26
(2,533 Views)
