11-27-2013 02:54 AM
Hello all,
Firstly, thanks by advance to all that could help me on this issue.
My problem is : I want to use the Distribution Kit tool, but not in order to install a program on a computer. In my case, I just want to use it to copy many files in specified directories. Thinking it will be easier than a kit with some .exe, I was mistaking because here is an error :
When I try to build my kit, Labwindows says :
- One or more projects need to be rebuilt before...
- There are no runnabble files in the project (Neither file .c nor file.uir in my project)
- The project did not built succesfully.
I know I can write a .exe to fix the building of my Distribution kit, but then, my client would have to run my Distribution kit to install folders and files, and would have to uninstall the .exe which would be useless.
I am working on CVI 8.5.
Thanks for reading, Vincent K
11-27-2013 03:08 AM
stupid question...: why not simply distribute a zip file?
11-27-2013 03:25 AM
I just want to do this the same way my predecessor use to do this in order to conserve homogeneity
