LabWindows/CVI
Docking graphs with legends in CVI 8.0
I have been quite happy with the new features of CVI 8.0's user interface library & editor. Well done, NI!
In particular I have been able to use splitters to dock native tab controls, and also have the contents of those tabs re-size or move (i.e. dock) within those tabs. Furthermore I've been able to dock child panels within those tabs, and either let them re-size/re-scale with the tab based on their panel attributes or give them resizing/moving behavior via docking with splitters too. All in a couple of hours! Awesome!
Okay, so here is my question: Is there a way to get graphs with legends to dock nicely when the legend is not lined up outside the graph in the lower right corner? I find that legends positioned over the graph or on the left respond strangely to being attached to splitters.  I have attached two images that show an example. (Note that bigger changes in size, or putting the legend on the left make for even more dramatic shifts.)
Thanks in advance!
--Ian
(3,157 Views)
Thank you for the nice words, Ian. It's good to know that you're finding these features useful.
Having said that, it does look as if you found a bug that happens when you size controls via splitters, that affects the placement of free-standing parts of controls (labels, legends and digital displays) depending on the position of these parts relative to the rest of the control. And legends are affected in a different way than labels or digital displays, although all three can be placed incorrectly.
We will fix this for the next version of CVI. In the meanwhile, I think your only option is to reset the position of the legend whenever you receive an EVENT_DROPPED event in the splitter's callback function.
Thanks for reporting this, Ian.
Luis
NI
(3,103 Views)
