LabWindows/CVI
How can I save current contents of several text-box as their default values In LabWINDOWS Executable?
I often need to change default value of text-box,hope can start up my labwindows executable
program with previous text-box contents. How can I do?Thanks for your attention.
(3,228 Views)
There is no way to store default values of controls directly in the executable, but you may want to save their contents to a file and recall them before displaying the panel, so that the panel is displayed with controls correctly filled.
To save all controls values in a panel  in a step only you can use SavePanelState function to store values in a file. RecallPanelState retrieves values from the file and puts them on the panel in a single call.
If you are concerned with one control only in a panel, you may want to do the same programmatically on this single control, saving its contents in a file with INIfile instrument or in the registry with instructions found in the Programmer's toolbox.
(3,207 Views)
I always get timely help from you ,thank you very much!
Happy New Year!Smiley Happy
(3,189 Views)
