LabWindows/CVI
Does CVI 6.0 support C++ ?
I would like to use the CVI enviornment to do some C++ tutorials since the MS Visual C++ SW is so unfriendly.
I'm not able to get the simplest of C++ programs to compile. The compiler chokes on COUT & CIN with IOSTREAM.H (all lower case). I've tried setting the includes to the MS includes without success.
When istalling CVI it show C/C++ as options.
What do I need to do?
Rick
(2,938 Views)
The CVI compiler supports ANSI C, not C++. You cannot use CVI to compile C++ code.
There are a couple of ways CVI works together with C++. To use existing C++ code within CVI, you can use a C++ compiler to create a DLL and call DLL functions from CVI. From with C++, you can load and call CVI library functions. C++ compilers can compile C, but ANSI C compilers (including CVI) can't compile C++.
(2,938 Views)
You would be surprised how many CVI experts think you can compile C++ programs.
Thank you, now I can put that C++ brick down and quit hitting myself in the head with it.
It would of been nice if the CVI troubleshooting seach engine had that information in it!
Rick
(2,938 Views)
