LabWindows/CVI
Drawing a Table in MS word using report generation toolkit
Hi all
I have been trying to generate a table on MS word using report generation  toolkit (please see the attached word document for the layout for the table).
please help
i m using labview 9.0 with report generation tool kit
help
regrads
Regards
(3,642 Views)
Hi nolsqn,
Just to clarify, are you using LabVIEW or LabWindows/CVI? You mentioned using LabVIEW in your post, but posted in a CVI thread. Also, what have you tried so far? The community will be able to point you in the right direction more easily if we know what you have tried and what isn't working.
John M
(3,621 Views)
hi
the CVI post was something different . I do know how to use the report generation tookit to draw tables ....but only simple ones. As i mentioned i am trying to make the table as in the word file attached above.
with regards
Regards
(3,607 Views)
Hi nolsqn,
I apologize for asking the same question, but are you using Report Generation in LabVIEW or in CVI? This post is in a CVI thread. If you are asking in regard to LabVIEW, we can support you better in the LabVIEW Forum.
Best Regards,
John M
(3,587 Views)
sorry
i thought this was the labview froum
my bad
regards
Regards
(3,511 Views)
