Duplicate Icon on Taskbar Application built using CVI
Application was built using CVI. It shows two windows on taskbar when only one should be present. How can I fix this issue. I have attached a snapshot of the problem.
(2,216 Views)
could it be that you have set the "Has Taskbar Button" attribute for your panel?
(2,145 Views)
