12-16-2016 04:06 PM
One day last week, LabWindows/CVI 2009 would not open. So I use the NI “Import Export Settings” to reset the settings from default. The next day, all my LabWindows programs were duplicating the panels (see below).
I tried reparing LabWindows and the repairing the run time engin, but neither has made a different.
How do I fix this?
Crashmagnet
Solved! Go to Solution.
12-19-2016
02:37 PM
- last edited on
08-03-2026
12:02 PM
by
Content Cleaner
Instead of re-install have you tried force reinstall?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGwJCAW&l=en-US
12-20-2016 07:53 AM
Ok, I tried forced reinstall and that didn't help.
Could this me some kind of debug screen or something?
12-21-2016 10:44 AM
Does the enviroment behave correctly?
Is this limited only to a single machine? Do the programs on that computer behave the same on another computer?
Are the problems just limited to built programs?
Is the whole process being duplicated or just the UI?
Can you recreate this issue with every single CVI project?
01-11-2017 09:41 AM
Please forgive my lateness. But I was distracted by the end of the year bru-ha-ha.
Everything works correctly, except for one other Interesting nit. LabWindows now compile my programs extreemly slowly. Like maybe 1/4 or 1/2 speed.
Thiis only happens on my machine.
This affects all LibWindows Programs. Programs compiled years ago, and programs I am try to compile right now.
I don't know what you mean by "whole process". The task manager only shows one program running, and there is only one process for the program.
Everything on the true panel works as expected. But nothing on the doubleganger panel works except the the command buttons on the upper right of the panel. The close and minimize buttons on the doubleganger work, but nother else on the doubleganger works.
This happens with every single LabWindows Program; programs compiled last year and programs compiled seconds ago.
Jeff Stout
01-12-2017 04:14 PM
Could I know more about your system?
What operating system are you using? What processor are you using for that?
Have there been any major changes on your computer side that coincided with the issue that you are seeing?
Best,
Shamik C
Applications Engineer
01-12-2017 04:27 PM
My system is a Dell Precission 6500
Windows 7; Intel i7 with 8 processors.
I was messing with some Nvida graphics settings at the same time. But I tried to undo them and it didn't seem to make any difference. Why would he graphics settings affect LabWindows programs, but no other programms?
Jeff Stout
01-13-2017 04:59 PM
Do you see this only when you open an application developed in CVI or do you see this when you look at your code in CVI?
Can you uninstall you nvida graphics card so that your processer defaults to the integrated graphics card to see what effect this has?
01-13-2017 08:20 PM
This only happens when I run a program developed by LabWindows. LabWindows runs just fine. But as soon as I push the start button, the compiled application (not LabWindows) starts displaying two windows.
I'll try your suggestion and get back to you later with the results.
BTW, you seem to have given up on the possibility that this is a LabWindows runtime engine issue. After all, this only seems to happen to running LabWindows programs. Is there really no possibility that there is something wrong with the LabWindows run time environment?
01-16-2017 04:54 PM
Let me know what happens when you reinstall the driver. Did you enable the option to always draw windows on-screen when you modified your graphics state when you were changing settings around?
