LabWindows/CVI
Dynamic DLL loading makes program crash
Dear NI Community,
I'm having a problem with a client's DLL. The DLL is created (by another of the client's supplier) using LabView / LabWindows.
I have a C++ code with dynamic dll loading looking like:
#include "'clientDLL.h"
typedef ViStatus regFunction(char*, unsigned long*);
char strPter[128];
int res;
void ext_call_getKernel(){
                res = getKernelVersion(strPter);
                cout<<"Kernel_Version returned "<<res<<" version = "<<strPter<<endl;
void loadDLL(){
        hinstLib = LoadLibrary("C:/Prober_Suss.dll");
        if (hinstLib != NULL)
            cout<<"HINSTANCE = "<<hinstLib<<endl;
            functionAddress = (LPTSTR) GetProcAddress(hinstLib, (LPCSTR)"clientsDLL_Register");
            localRegister = (regFunction*)functionAddress;
        if (*localRegister != NULL){
            cout<<"procAddr Register = "<<functionAddress<<endl;
            res = localRegister(AppName, &sessionLong);
            cout<<"Register returned "<<res<<" session = "<<sessionLong<<endl;
                    if(sessionLong != 0){
                functionAddress = (LPTSTR) GetProcAddress(hinstLib, (LPCSTR)"Kernel_Version");
                getKernelVersion = (getStringFunction*)functionAddress;
                for(int i = 0; i < 12; i++){
                ext_call_getKernel();
This code works until ext_call_getKernel(), the whole program stops with (gcc)debugger message :
RUN FAILED (exit value 1 875 677 888, total time: 4s)
        Any idea on what could make this kind of problem appear, and how to resolve it?
(4,916 Views)
Hello Sylvio,
Is it possible to update a little project that reproduce the error?
BR,
Jovan N. - Application Engineering
(4,814 Views)
Dear Jovan,
Unfortunately I cannot send the client DLL so it would be useless...
By the way, we have been given a new version of clientDLL which loads in static (#include "clientDLL.h"); this way we avoid the problem.
Thank you for your answer;
HS
(4,804 Views)
