EVENT_TABLE_ROW_COL_LABEL_CLICK only for left clicks?
I wanted to make use of the EVENT_TABLE_ROW_COL_LABEL_CLICK event in sorting a table column, unfortunately it appears to be fired only for mouse left clicks and not for mouse right clicks (while the help says 'When a user clicks a row or column label...' -> probably it shoud read 'When a user right clicks a row or column label'?)
I need the EVENT_RIGHT_CLICK to use RunPopupMenu to show a custom Sort menu (the built-in Sort menu appears to only sort the selected column, which I find not very useful...) and was hoping to get the column index from the EVENT_TABLE_ROW_COL_LABEL_CLICK 😞
Yes, I have seen the example colview and its function GetClickedColumnLabel - it appears to be the only possibility?
Thanks!
Wolfgang
(3,737 Views)
Accepted by Wolfgang
When thinking more about it it appears that I am looking for an event EVENT_TABL​E_ROW_COL_​LABEL_RIGHT_CLIC​K, hence I have suggested it here
(3,730 Views)
I was trying to find a way to somehow modify the  EVENT_TABL​E_ROW_COL_​LABEL_CLIC​K but as you mentioned it only fires for left-clicks. The idea with the idea exchange is therefore the best way to proceed.
Regards, Jan
(3,714 Views)
Thanks for confirmation, Jan!
(3,712 Views)
Wolfgang, why not just call your callback function recursively upon the EVENT_RIGHT_CLICK event, passing the EVENT_TABLE_ROW_COL_LABEL_CLICK parameter.  I do something like this often and get expected results.  It would look something like:
int CVICALLBACK TableFunction (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
	Point cell;
	int row, column;
	switch (event)
		case EVENT_LEFT_CLICK:
			break;
		case EVENT_RIGHT_CLICK:
			/* eventData1 = mouse vertical pos., */
			/* eventData2 = mouse horizontal pos. */
			// extract mouse position in the table
			GetTableCellFromPoint(panel,control,MakePoint(eventData2,eventData1),&cell);
			column = cell.x;
			row = cell.y;
			// setup for sorting here
			TableFunction (panel, control, EVENT_TABLE_ROW_COL_LABEL_CLICK, void *callbackData, int row, int column);
			break;
		case EVENT_TABLE_ROW_COL_LABEL_CLICK:
			/* eventData1 = row, eventData2 = col */
			// sorting stuff here
			break;
		case EVENT_COMMIT:
			break;
	return 0;
(3,445 Views)
