06-27-2007 04:11 PM
06-28-2007
03:41 PM
- last edited on
07-08-2025
01:05 PM
by
Content Cleaner
Hi Skim,
It sounds like the Traditional NI-DAQ drivers were not re-installed after upgrading CVI versions. When upgrading versions of CVI, the NI-DAQ drivers need to be re-installed as they only originally install support for software they find present at the time. When you install the latest version of Traditional DAQ (7.4.4), which includes support for CVI 7.x and later, it will install support for your new version of CVI and you will be able to again find the functions you are used to for Traditional DAQ.
06-29-2007 07:41 AM
06-29-2007 12:11 PM
AFAIAA there is no equivalent of Easy I/O for DAQmx. Only Difficult I/O 🙂
But seriously, DAQmx is pretty easy once you have grasped the concepts and used the wizards.
06-29-2007 12:29 PM
Skim,
I would suggest looking at the AO shipping examples, as these are great to start out with and then build off of. (Help >> Find Examples…>> Hardware Input and Output >> DAQmx >> Analog Generation >> voltage)
07-02-2007 08:34 AM
