LabWindows/CVI
Edit Installer IDE bug when creating registry keys
In the Installer Editor (CVI 9.0.1), I'm getting weird behavior and then (sometimes) a "Custom callback raised an exception" error and then (sometimes) a "CVI stopped working" crash.
The problem seems to start in the "Registry Keys" tab, and I can reproduce it by adding several keys under HKLM\SOFTWARE\Classes\. Next, I add a new child key under the last one listed. Instead, it adds a new sibling key, which also has a new child. Please see the attached image, which was done after loading the colorpicker example project. Those last two "New Key" items circles should have been one child of the one above.
Once this unexpected sibling (with child) problem occurs, all bets are off, especially if I continue to edit and attempt to fix things. The new installer registry key entries do not necessarily get saved, and the IDE often stops working.
--Ian
(3,458 Views)
Thanks for the thorough description. I've created a bug report for this issue (#192040), and we'll fix it in a future release.
Mert A.
(3,454 Views)
The essence of the problem appears to be that if you change a key's name, then click a different item, the name change does not get applied. You can confirm this behavior if you OK the Edit dialog, and then re-enter it: the key name will have apparently reverted.
For now, you can avoid this by always hitting Enter after editing the name of a key (both when creating a new key, or renaming an existing key).
Mert A.
(3,450 Views)
Thanks, Mert, for the helpful follow-up.
(3,422 Views)
