LabWindows/CVI
why my applications asks for internet access?
every time i compile an application my firewall (NIS 2009) complaints that "MyProgram.exe" asks for Internet access! Although i'm building just a simple app with the message "hello wold" (i mean i dont use any libraries that uses my network) can i stop this..?
(3,216 Views)
Karpa,
Does this happen if you close down CVI, open it up again, and run one of the examples from Help » Find Examples ? Also what version of CVI are you using, and does this happen on any other computers with the same firewall?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,182 Views)
yes this is happening with all applications every time i compile and run it.. The reason is that every time i build the application the firewall recognize it as NEW executable that tries to gain access.. even though i block the application it works correct. i think it has something to do with the RTengine.. but i have no idea how to stop it.. the CVI version is 8.5. with version 5.5 (i tested) same problem.
(3,137 Views)
