LabWindows/CVI
Editable listview
Is it possible to edit at runtime by a user the subitems in ListView ActiveX control ?
If yes, could someboby post some examples of this code.
Thank you.
(5,337 Views)
Could you short tell me what product of NI do you use ? Labview or CVI and what version ?
In Runtime you could only edit what you have programmed before with property or invoke nodes - not more
Best Regards
(5,307 Views)
Hello Mr. Wagner
thank you for answering, i am using LabWindows/CVI 8.5. I have tried to programm an at runtime editable listview activex control. For example i would like to change the subitem values by typing on the keyboard a new text in it, something like you can do it in C++ or Visual Basic 6.
But i could not find out how to make the subitens editable at runtime.
If there is a way to make it possible, please post a little example.
Thank you.
(5,295 Views)
i attached here a screenshot how you have access to the sub items properties and methods in labview. The same is in labwindows/cvi. Hope there is the right issue you need e.g.
property value - connect it to a value control and so you can change write it while runtime...
(5,292 Views)
Just curious as to why you are using an activex control instead of the native tree control in CVI?
You can edit CVI tree control items at runtime by hitting <F2> (if the attribute ATTR_NO_EDIT_LABEL is not set).
(5,271 Views)
Well, the tree control is not realy what i need. I could not find any possibility to view data as a table in this control.
If you can show me how i can do this, i would appreciate your help.
Thank you.
(5,252 Views)
Thank you, Mr. Wagner for your help.
I can fill out the listview control with listitems and with subitems, i can fill out the values of subitems, but this values could not be changed  by a user at runtime.
In a file you posted i think what is about. But i could not understand how to solve my problem anyway.
Boris
(5,251 Views)
