LabWindows/CVI
what is the difference between Degug executable and Release executable file?thank you
as the title says:
Can the Degug executable   be used as a normal executable   file?
thank you
(3,055 Views)
Yes, the debug can be used as a "normal" executable because it does execute; however, it will carry around more overhead with it as it contains a lot more data on vraibales, etc, to allow the debugging.  If yu don't care about time or space, it won't matter at all.
(3,039 Views)
