Enabling editable graph axes from the UIR editor
Hi, everyone!
This feels like a silly question, but I cannot find what I'm looking for, or I don't understand my problem. I want to make the axes of a graph editable, so the user can enter a value directly to change the range displayed in the graph. I want to do this from the UIR editor, but I can't seem to manage...
I found this command: https://zone.ni.com/reference/en-XX/help/370051AG-01/cvi/uiref/cviattrenableeditableaxes/, which sounds like what I want to do.
What I have found so far: If I edit my graph, I can check "Editable graph axes" and set my graph control mode to hot. This does not seem to be enough. The link above speaks of a setting called "axis mode", which should be set to VAL_MANUAL or VAL_LOCK. This could be my problem - because I cannot find this setting in the UIR editor.
Help?
(1,241 Views)
Accepted by guybrush_threepwood
Setting an axis graph to manual scaling simply means to uncheck autoscale attribute on that axis, this way:
(1,210 Views)
Aha! Thank you very much! 😄
(1,187 Views)
