LabWindows/CVI
Entering NaN in CVI variables window
Does anyone know how, or if it is possible to edit a variable value to be NaN in the variables window when debugging?
Not that I need it now, but am curious about entering -Inf and +Inf too.
I'm running CVI version 8.0.
Darrin.
(3,035 Views)
You can do this in the Watch window. Add a watch expression like the following:
var = 0.0 / 0.0
The above will result in var getting assigned to NaN. You can use similar right-hand expressions to get -Inf and +Inf. After you get the desired value, make sure you delete the watch expression before you continue program execution - this is required to prevent subsequent evaluations of the watch expression.
(3,014 Views)
