LabWindows/CVI
Error loading examples
Hi All,
Im new to cvi.I am using CVI 7.1 evaluation version.Everytime I try to run an example from NI Example Finder i always get an error ,for example I want to run example update.prj, I get error message
 "error writing file c:\.....\cvibuildupdate\update.nidobj"[file access permission denied]" anyone have any idea how to solve this problem? Thanks a lot for yr time
y_m_h
(3,869 Views)
Accepted by y_m_h
This sounds like an IT permissions issue - I'm guessing that on your computer you are not allowed to write to any c:\program files... areas? (Which is where the CVI samples normally get installed.) Just copy the examples into a drive area where you do have write permission and I'm sure all will be well.
JR
(3,866 Views)
Thanx for your reply. I guess you are right, since I dont have the right unless the administrator in the company im working.Thanx again
(3,863 Views)
