LabWindows/CVI
Error opening sample program.
CVI Popup window states:
Unable to open workspace file "c:\..\..ChangeDetectionEvent.cws" (The tag "version" is missing from the section [Workspace Header] or it has no value.)
To edit the workspace file in a LabWindows CVI source window you must rename the file so that it has an extension other than ".cws" .
 OK?
I tried reloading the sample programs from the disc but it still happens.  It seems not to occur with other sample programs.
What do I do?
(4,650 Views)
Hi CVIJoe,
What version of CVI are you using? Also, please tell me where the example is located on your machine This seems like a problem with the example itself rather than CVI since all the other examples are working, but its definately strange that the on disc file didn't work either.Once I get thatadditional information from you, I will take a look at the correct file to see what could be going on. Thanks!
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(4,627 Views)
Hi Al,
I'm using CVI version 8.5.1.  The sample's path is c:\Documents and Settings\All Users\Documents\National Instruments\CVI\samples\DAQmx\Events\Signal\Change Detection\Read Dig Chan-Change Detection Event\ReadDigChan-ChangeDetectionEvent.cws .
Seems pretty long too me, could that be it?  I reinstalled the CVI samples from the Installation CD.  It's path is D:\Parts\CVI\Samples\CVISamples.msi .
Thanks for the quick reply.
(4,604 Views)
Accepted by CVIjoe
Hi CVIJoe,
I think your file is somehow corrupted, and the reinstall is not overwriting it.  I found the file on my machine, and it contains the version tag mentioned in the error.  I have attached my file, so go ahead and try replacing your .cws file with this one, and let me know what happens.  Hope this helps!
Al B.
CTA/CLD
(4,602 Views)
Replacing your .cws with mine worked.  I'm able to open the workspace and run the app in debug mode.   However I'm getting a NON-FATAL RUN-TIME ERROR on function DAQmxCfgChangeDetectionTiming (return value = -200077) when I start acquiring samples. Maybe I should start another thread for this problem?
Thanks again for the quick reply,
(4,597 Views)
Hi Joe,
This error seems to be related to an incorrect value for AI.max or AI.min.  the following article addresses this error:
http://digital.ni.com/public.nsf/allkb/440EB533229211CD8625711C007E61B3?OpenDocument
If this does not fix the problem, creating a new post in the DAQ forum would be the best way to get an answer.  Thanks!
Al B.
CTA/CLD
(4,579 Views)
