LabWindows/CVI
Excel Overwrite Question
I am using the Excel Report fp along with CVI 8.0.
How do I suppress the file overwrite prompt generated by excel when I initiate the following command ExcelRpt_WorkbookSave ?
I am first using a FileSelectPopup to prompt the user to create or select a file. If a file that already exists is selected, an overwrite prompt appears which must be selected.
This is ok.
However, when the ExcelRpt_WorkbookSave function is executed, excel will then launch another prompt on its own.. I need to suppress this second prompt.
Diego
(4,810 Views)
While I cannot say anything on the second message, the one on FileSelectPopup is only shown if you choose "Save" as the button label: either choosing "OK", "Select" or "Load" prevents from showing the confirmation message.
(4,802 Views)
Roberto,
Good solution, thx.
I am still curious if there is a way to suppress the excel prompt.
Diego
(4,790 Views)
I don't think there is a way to do it directly.
You may have to save the worksheet to a temporary file, delete the original file, then rename the temporary file to the original filename.
Martin
Certified CVI Developer
(4,787 Views)
