LabWindows/CVI
waht's the Difference between NI visa and Agilent Visa
I found if I want write a GPIB command to instrument,there are some difference between uesing NI VISA  and Agilent VISA.
viPrintf(vi,":POW?\")   from agilent
viPrintf(vi,"POW?")  for visa
 where : is used in first one is necessary?
(4,122 Views)
\P 😛
(3,921 Views)
Firstly, if instrument which you're using can be drived by NI VISA or Agilent VISA, you can use any one to program. Also the difference between these two functions are inherent for being defined by drivers.
Secondly, once in the same computer, I suggest that you'd better use only one driver to avoid conflicts or some else problem.
Best Regards,
NI Application Engineer
(3,868 Views)
