LabWindows/CVI
Why does LabWindows CVI 8.1 require LabView Run-time engine 7.1.1 install when started
When I start LabWindows CVI 8.1 a dialog appears requesting to insert the NI LabVIEW Run-Time Engine 7.1.1 disk.  I cannot find this disk included with my LabWindows/CVI installation kit.  Why does LabWindows/CVI require a LabVIEW install disk?
Message 1 of 8
(6,073 Views)
I was having this same problem just two weeks ago, or so.  I have CVI 8.0 and had installed Labview 8.2 but hadn't done much with it.  Then, mysteriously, this error started popping up.  I could not figure out what was happening.  I uninstalled Labview.  I eventually had to un-install CVI also and then re-install it.  There were other gremlins running around related to NI products, but the total wiping and re-install seemed to clear them up.
Message 2 of 8
(6,059 Views)
If you could provide us with some information we may  be able to track down why this is happening.
The next time the installer dialog pos up follow this procedure:
Right Click on "My Computer" and select Manage.  Then go to the event viewer and look at the Application event logs.  In here you should find some MSI Error logs that tell us what GUID and what file it could not find and was trying to repair.
-Jeff
NI
Message 3 of 8
(6,022 Views)
Thanks for you suggestion it was ultimately the same approach I used to resolve the issue.  This was  a bit of a bummer since LabWindows/CVI is a pretty lengthy install when you include the device drivers.
Message 4 of 8
(5,966 Views)
I have the "LabView Run-time engine 7.1.1" install error occur constantly and in programs that have nothing to do with NI or its instruments.
This is what is in the event log when the error pops up =>
Detection of product '{53736430-DBEC-4582-B072-2F1F0A2C4EA6}', feature 'DataSocket.LVW71RTE' failed during request for component '{5A3D4E5B-019F-47C0-9466-5E741D14CF50}'
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Detection of product '{53736430-DBEC-4582-B072-2F1F0A2C4EA6}', feature 'DataSocket.LVW71RTE', component '{713943EB-D52A-4905-AAB9-22542176A4B2}' failed. The resource 'C:\Documents and Settings\All Users\Start Menu\Programs\National Instruments\DataSocket\' does not exist.
Product: NI LabVIEW Run-Time Engine 7.1.1 -- Configuration failed.
Do I have to reinstall all of the NI stuff to get this to go away?   I have two computer that are doing this now.  Seemed to occur after installing NIDAC stuff.
Message 5 of 8
(5,480 Views)
phmoore,
Can you navigate to the folder mentioned in the error log? (C:\Documents and Settings\All Users\Start Menu\Programs\National Instruments\DataSocket)  If not, is there a similar folder under C:\Documents and Settings\Administrator\Start Menu... or C:\Documents and Settings\<your user name>\Start Menu... ?  If there is a similar folder there, try moving it to the All Users path and see if that resolves the issue.
What programs are you trying to run when you get this error?  And what version of NI-DAQ did you recently install that may have caused the problem?
Eric B.
Message 6 of 8
(5,460 Views)
Eric,
I moved the "National Instruments" start menu folder back to be under "All Users\Start Menu\Programs" in both of my computers.  This fixed the problems instantly.
The NI-DAQmx software I installed is version 8.7.1 (Windows XP).  The programs I run are: Visual Studio 6 (happens when Visual Studio started), MCE Designer - a vendor supplied GUI (happens whenever a submenu is opened or display box pops up).
I had reorganized the start menu folder using subfolders in both computers that have this problem.  I have way too many programs to keep everything on the top start menu level.  Do I have to keep the National Instruments folder in this start menu place?
Thanks for your help.
-Paul
Message 7 of 8
(5,453 Views)
Paul,
The short answer to your question is "yes". There may be some way to change the reference to that DataSocket folder, but I am not aware of one.  I will look into this to see if that is possible, but for now, those files have to stay in your Start menu.
Eric B.
Message 8 of 8
(5,422 Views)
