Excel Report - incorrect results when writing floats
double d = 5.1;
float f = 9.2;
// (open an Excel worksheet)
// This writes the correct value
ExcelRpt_SetCellValue(worksheet, "A1", ExRConst_dataDouble, d);
// This writes junk -- 1.9E+19 or something similar
ExcelRpt_SetCellValue(worksheet, "A2", ExRConst_dataFloat, f);
(3,667 Views)
Hi richferrara
What version of LabWindows™/CVI­™ and Microsoft Excel® are you using?
Andy F.
Applications Engineering
(3,645 Views)
I'm running LabWindows 2015.  I've seen the same result using Excel 2010 and 2013.
(3,634 Views)
Accepted by richferrara
Hi richferrara
I was able to replicate your behavior and will be looking for any existing Corrective Action Reports on our end to see if we already have this documented. I did find that whenever you set the data type enum for your float write to "ExRConst_dataDouble" that it writes the value correctly. I'll continue looking into this issue and post what I find.
Andy F.
(3,615 Views)
