LabWindows/CVI
Excel Report - incorrect results when writing floats
double d = 5.1;
float f = 9.2;
// (open an Excel worksheet)
// This writes the correct value
ExcelRpt_SetCellValue(worksheet, "A1", ExRConst_dataDouble, d);
// This writes junk -- 1.9E+19 or something similar
ExcelRpt_SetCellValue(worksheet, "A2", ExRConst_dataFloat, f);
(3,669 Views)
Hi richferrara
What version of LabWindows™/CVI­™ and Microsoft Excel® are you using?
Andy F.
Applications Engineering
(3,647 Views)
I'm running LabWindows 2015.  I've seen the same result using Excel 2010 and 2013.
(3,636 Views)
Accepted by topic author richferrara
Hi richferrara
I was able to replicate your behavior and will be looking for any existing Corrective Action Reports on our end to see if we already have this documented. I did find that whenever you set the data type enum for your float write to "ExRConst_dataDouble" that it writes the value correctly. I'll continue looking into this issue and post what I find.
Andy F.
(3,617 Views)
