LabWindows/CVI
Exe encounter problem with labwindows
I also encountered a similar problem right now. I made a program using Labwindows, using another dll, and GPIB/GPIB 488.2 Library & Word2000.fp instrument files. I met two issues:
1) My exe program runs well for almost 50 hours and then was stopped with error message: "X has encountered a problem and needs to close...". In the Error signature appeared the dll that I used in my program in ModName.
2) In UI of the program, there is a button to create Report (making a graph, put a table of results into the doc file, and then insert the graph after the table). If I click that button, the same error message as above appeared. In the Error signature appeared cvirte.dll in ModName.
I captured these two errors in the attached files.
How can I identify where the bug is? and How should I do to solve this problem?
Thank you very much.
Lien
Message 1 of 1
(3,108 Views)
