LabWindows/CVI
Teststand & LabWindows/CVI Datatypes mismatch
I didn't know where I should post my problem but I decided to place it to the LabWindows/CVI forum. I have a problem using an ivi driver in Teststand with the Labwindows/CVI Adapter. When I'm compiling my ivi specific driver (or generating a class driver) the parameter datatypes are not correctly recognized by Teststand. When I load a module and select a function in the Testand Sequence Editor some datatypes are mismatched.
I have a High Level Function in my driver which looks like this one:
ViStatus _VI_FUNC Prefix_read_XXX (ViSession vi, uint8_t *result, uint8_t length, uint16_t errorCode)
the Datatypes are defined in a Headerfile (stdint.h, included in prefix.h):
#ifndef __STDINT_H
#define __STDINT_H
typedef char int8_t;
typedef unsigned char uint8_t;
typedef signed short int int16_t;
typedef unsigned short int uint16_t;
typedef signed long int int32_t;
typedef unsigned long int uint32_t;
#endif /* __STDINT_H */
Teststand always recognizes a long for ViSession (should be unsigned long) and a short for uint16_t (should be uint16_t = unsigned short). Sometimes, if i disable the type library, or use the __stdcall convention in the Build Options it works (sometimes I have also to enable the Default Base Library Name in the target settings options) ... the datatypes are correctly defined in the function panel (Options > Datatypes...).. I also tried to specify the "intrinsic datatypes" but this doesn't work... options > ivi&vxi plug&play style is enabled... does anyone have an idea?
(4,498 Views)
I used LabWindows/CVI 8.1 and everything worked fine until I updated to 8.5. The problem occurs now with both versions. I have also reinstalled the IVI Compliance Package to be able to use the IVI Library in LabWindows 8.5. There is also another problem with the session manager which I posted in another thread (here) some weeks ago. Could there be any relationships between this problems and the update?
(4,454 Views)
Hi 7even,
could you please add your teststand and CVI Programm, so we can have a look at it? If you do so, please minimize (cut) the code as much as possible.Just enough to rebuild the problem.
Thanks and Regards,
Matteo
(4,413 Views)
