Extracting numbers from a char array
I am using LabWindows/CVI to read data from a serial port.  I read the values with ComRdTerm, and they are stored in a char array, the
array looks like this "1024 576 123 756". I need to extract the numbers from this array.
(3,684 Views)
Accepted by adrian_necula
ANSI C sscanf () and Formatting and I/O Library Scan () functions are the instrument you can use to extract your numbers. A good C manual will explain you the first command and its options, while for the second there exists a good descrption in the online help.
(3,676 Views)
Thank you, it worked
(3,661 Views)
