LabWindows/CVI
FTP session behind a firewall
Hi all, I am developing an application that must transfer some files using ftp but I am getting errors I don't know how to interpret and resolve.
I am accessing the internet through a firewall installed in my office, and according to the documentation, I must switch to low level functions if a firewall is present in the connection. My problem is that I receive the error -9 (Cannot connect to FTP server) in InetFTPLogin. Smiley Sad
According to this discussion I should use InetFTPSetPassiveMode after the login, but my problem is that I am not able to log in! Smiley Mad
If I use the IP of the FTP server instead of standard ftp://ftp...... notation I can connect without problems, but I cannot expect my customer even knows the IP address of its FTP server!
I then tried to use Windows API calls (see the sample attached), and I get error 12007 in InternetConnect function even if I use INTERNET_FLAG_PASSIVE flag; this error means:
   12007       ERROR_INTERNET_NAME_NOT_RESOLVED
               The server name could not be resolved.
I receive this error both connecting to my ftp server with proper user and password and connecting to an ftp server that accepts anonymous connections using standard "anonymous" + blank-password or "anonymous" + email-address-as-password methods. I can access both servers when using the browser. Even in this case, if I use the IP address the function gets no errors.
What can be the error and what can I do to solve it?
Thank you all
Message Edited by Roberto Bozzolo on 04-03-2006 09:56 AM
(4,284 Views)
Surely InetFTPLogin() takes the plain name of the server, not a URL. So you should specify (for example) "ftp.grotty.com" as the first parameter of InetFTPLogin, not "ftp://ftp.grotty.com".
Martin
Certified CVI Developer
(4,272 Views)
Ufff, Martin, you're absolutely right!
Lost in the ocean of parameters and help files I missed this "little" Smiley Surprised detail.
Many thanks for your suggestion. Smiley Wink
BTW, this also applies to InternetConnect API...
(4,265 Views)
