LabWindows/CVI
When I use installshield to distribute, i get error 2705 with merg modules
If I try to include CVI 8.0 Merge modules in installshield developer 8.0, i get "Internal Error 2705. Directory"   I am not using any languages aside from English and it is just a very simple installation.
the merge modules included are ivipaths, the runtime engine, mkl.msm, activex container, nianalysis dll,
ni installer utilities, niMesaDLL, VC User CRT71 RTL X86, VC User STL71 RTL X86.
I have tried everything to fix this, but it seems like the problem is caused the activex container or one of the modules dependent on it.
Message 1 of 10
(5,588 Views)
part of my installshield error log:
Action start 9:51:28: AppSearch.
Action ended 9:51:28: AppSearch. Return value 1.
Action start 9:51:28: CheckIviSystemRequirements.638572CD_A008_4A0F_ABA6_5F55F60AF033.
Action ended 9:51:28: CheckIviSystemRequirements.638572CD_A008_4A0F_ABA6_5F55F60AF033. Return value 0.
Action start 9:51:28: GetIviPaths.638572CD_A008_4A0F_ABA6_5F55F60AF033.
Action ended 9:51:28: GetIviPaths.638572CD_A008_4A0F_ABA6_5F55F60AF033. Return value 0.
Action start 9:51:28: NIMUMetaHook.91D5760B_F9E8_4332_BFB1_38A4CB799A3E.
Action ended 9:51:28: NIMUMetaHook.91D5760B_F9E8_4332_BFB1_38A4CB799A3E. Return value 0.
Action start 9:51:28: NIPaths.91D5760B_F9E8_4332_BFB1_38A4CB799A3E.
Action ended 9:51:28: NIPaths.91D5760B_F9E8_4332_BFB1_38A4CB799A3E. Return value 0.
Action start 9:51:28: LaunchConditions.
Action ended 9:51:28: LaunchConditions. Return value 1.
Action start 9:51:28: FindRelatedProducts.
Action ended 9:51:28: FindRelatedProducts. Return value 1.
Action start 9:51:28: NIFindRelatedProducts.91D5760B_F9E8_4332_BFB1_38A4CB799A3E.
Action ended 9:51:28: NIFindRelatedProducts.91D5760B_F9E8_4332_BFB1_38A4CB799A3E. Return value 0.
Action start 9:51:28: ValidateProductID.
Action ended 9:51:28: ValidateProductID. Return value 1.
Action start 9:51:28: NIMUPersistPartRegInfo.91D5760B_F9E8_4332_BFB1_38A4CB799A3E.
Action ended 9:51:28: NIMUPersistPartRegInfo.91D5760B_F9E8_4332_BFB1_38A4CB799A3E. Return value 0.
Action start 9:51:28: CostInitialize.
DEBUG: Error 2705:  Invalid table: Directory; Could not be linked as tree.
MSI (c) (C8:14) [09:51:30:421]: Product: myproduct -- Internal Error 2705. Directory
Action ended 9:51:30: CostInitialize. Return value 3.
1: Failed to launch action 'CostInitialize', error is 1603
Message 2 of 10
(5,586 Views)
by the way, yes there is a program files folder defined in the table, so that is not the problem.   Also NiMetaUtils is included (these are 2 problems that i heard can cause this)
Message 3 of 10
(5,583 Views)
Hello gbedford,
So in order to further debug this situation, would it be possible for you to post your MSI file so we can take a look at it and see which directories are being populated incorrectly.  If you cannot post this on a public forum, please email it in to us at ni.com/support (Option 2: Email NI) which will creating a service request on the issue.
Wendy L
LabWindows/CVI Developer Newsletter
Message 4 of 10
(5,535 Views)
sorry i realized i  have this conversation going on in this thread and http://forums.ni.com/ni/board/message?board.id=232&message.id=3065   as well.
I sent my project through the email form.  It is an IS 8 project
Message 5 of 10
(5,489 Views)
I posted it on the ftp site a week or so ago.  Did you get it ok?
Thanks.
Message 6 of 10
(5,405 Views)
Hey gbedford,
I did not realize you had posted it on the ftp because you had said you emailed it in.  Could you please repost it, and also do you have the service request number that you sent the email in under?  Just post here after you have posted it on the ftp.  The folder was installshield and the ftp is ftp.ni.com/incoming.
Pat P.
Software Engineer
Message 7 of 10
(5,373 Views)
Reference#7107349
I have uploaded the project to the installshield folder.
Greg
Message 8 of 10
(5,346 Views)
Hey Greg,
Just wanted to let you know we did receive the file successsfully, and R&D is aware of it.
Pat P.
Software Engineer
Message 9 of 10
(5,320 Views)
thank you
Greg
Message 10 of 10
(5,315 Views)
