Fault Tolerant Programming in RealTime
As rolfk mentioned, strtok is not multithread-safe, use strtok_r instead. It may not be important in your case, but I don't what else your program is doing and you mention real-time, so...
Message 21 of 24
(1,536 Views)
I have no such function in my library.
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
Message 22 of 24
(1,522 Views)
Hmmm, yeah, the '_r' multithread-safe variants of standard C functions haven't made it to CVI yet in most cases. But they are easy enough to find in open-source source code and add to your projects...
See here.
This should actually be on the CVI Christmas suggestion list...
Message 23 of 24
(1,514 Views)
I have not had the mystery source error since changing to strtok_r.  I will report back if anything changes.  Thanks all!
Message 24 of 24
(1,431 Views)
