File Formating
I am sending and monitoring messages through the COM port.
I am taking the data that I am receiving and storing into an array (hex format)
I would like to Write the time(hh:mm:ss) and the results from the buffer into a file (xls).
For example column A would be Time and B to whenever holds the bytes received from the COM port.
Each message that I receive I want to write the time and the data, and then moved to row 2 and etc.
I am using the sprintf to format the time and the writeline to output it to the file - that works
I am using the arraytofile to ouput the data - that works
The problem that I am having is that it puts all the times first and then after will put the data (all in column A)
Any help would be appreciated.
(4,275 Views)
If i correctly understand your problem, you could use sprintf to generate a row with time and data separated by tabulator ('\t'), next writeline it to the physical file wich will be automatically separated into columns when loaded in excel:
sprintf (msg, "%s\t%f", TimeStr (), data);
or even simpler
FmtFile (fileHandle, "%s\t%d\n", TimeStr (), data);
(4,265 Views)
Thanks for your help,
I just want to clarify a little:
Here is an example that I would like to do:
buffer[0] = 0xAB
buffer[1] = 0x11
buffer[2] = 0x33
buffer[3] = 0x17
Please note that the #of bytes stored in the buffer changes based on the message i receive, some messages will be 6 bytes in lenght and others will be like 15 bytes.
Now when i write to the file I would like the following format in excel:
Columns:  A                B                    C                D                         E
               hh:mm:ss    0xAB              0x11           0x33                  0x17
Is there a better way to do this other than:
sprintf (msg,"%s\t%x\t%x\t%x\t%x",TimeStr(),buff[0],buff[1],buff[2],buff[3])
The reason I ask is because the # of data bytes changes.
Any help would be much appreciated!
(4,256 Views)
Accepted by BJD17
Well, not the best solution you can find, but:
int        count, buf[15];
char    msg[256];
buf[0] = 0xAB;
buf[1] = 0x11;
buf[2] = 0x33;
buf[3] = 0x18;
buf[4] = 0x19;
buf[5] = 0x20;
buf[6] = 0x21;
buf[7] = 0x22;
buf[8] = 0x23;
buf[9] = 0x24;
count = 5;
Fmt (msg, "%s\t%*x[j3]\t", TimeStr (), count, buf);
Changing the value of 'count' changes the number of data written to the destination (Fmt can be replaced with FmtFile simply passing a file handle instead of a string): e.g. with count = 5 the output is  "14:30:29 ab 11 33 18 19 ".
One problem of this solution is that it adds a separator after the last element has been written to the destination, the other is that you cannot have the '0x' prefix before data.
(4,251 Views)
Thanks Roberto!!! much appreciated
(4,246 Views)
