LabWindows/CVI
File acces permision denied
Hi
Recently when I start CVI with the project I'm working on I get the error message "File access permision denied".
I bellive it started after a Windows update.
I have CVI 2013 servicepack2 and Win7
Regards Per
Message 1 of 8
(5,970 Views)
Dear Fluidtronic,
What did you update through Windows update? Was it any security settings that changed?
Best regards
Message 2 of 8
(5,862 Views)
Hi. I don't know. I have automatic update. Windows only state "innstalling update 1 of X"
Message 3 of 8
(5,858 Views)
Dear fluidtronic,
One thing you can try is to move the project on disk and see if that makes any differense. Otherwise I will recommend you to uninstall CVI and install it again. It might be that after windows update some new settings have been made that blocks the environmen, this happens.
Best regards
Message 4 of 8
(5,776 Views)
Hello
I copied the project to a pen drive. I can open and edit from there.
I tried to delete the .cws and .prj file and created a new .cws. in the same location. This still has File Acces permision denied.
Looks if I have to reinstall.
Message 5 of 8
(5,769 Views)
Accepted by topic author fluidtronic
Dear fluidtronic,
Well, If you get it to work from your pen drive. I  don't think the CVI installation is the problem here. Instead I recommend you to look att the file and catalog read/write privileges.
Best regards
Message 6 of 8
(5,764 Views)
Make sure you are not writing to a folder under Program Files or Program Files (x86)
Message 7 of 8
(5,760 Views)
Hi lhedlund
Pretty basic and had nothing to do with CVI. It was as you indicated the whole folder (with it's sub folders) was "Read only"
How that happend I don't know. Thank you.
Message 8 of 8
(5,736 Views)
