LabWindows/CVI
Opengl solution compatible in 32 bits and 64 bits systems
hello,
I used cviogl instrument of Labwindows CVI 2010 for OpenGL visualisation in 32 bits systems. But, this instrument is not compatible for 64 bits systems.  I just wana know if there is a OpenGL solution 32bit and 64 bit compatible?
thanks in advance.
Julio
(3,849 Views)
Hi Julio,
OpenGL control in CVi is not supported for 64 bits applications as you can see on that link.
You could think of using a 3rd party OpenGL calling the DLL from CVI. You'll find help on how to do so on this forum.
I hope this helps you.
Have a nice day,
M-Junior
(3,830 Views)
Hello Marc,
thanks for you reponse.
I found a another solution, I use an opengl and a Glu intruments for cvi (found on internet several years ago). Theses instruments are compatibles for 32 and 64 bits systems.  Now, i programing a opengl control like cviogl.
Have a nice day,
Julio
(3,819 Views)
Hi Julio,
Could you provide a link for downloading the OpenGL instrument driver you found on the internet?
Best regards
(3,338 Views)
