LabWindows/CVI
FileExists() on FAT32 Compact Flash Card
I'm currently using FileExists() to check for a file on a compact flash card through a USB reader.  The card is formatted for FAT16.  The product that uses the card now supports FAT32 so I formatted the card to that and can see and read the file through the reader.  My call to FileExists() that works on the FAT16 card now returns UIEIOERROR (-93).  Does FileExists() only support FAT16?  Should I be using another function?  I'm using CVI 8.5.1.  Thanks.
(2,928 Views)
Hi CareFish,
There is a KnowledgeBase Article with a few other functions you might want to try.
Hassan Atassi
Senior Group Manager, Digital Support
(2,913 Views)
