LabWindows/CVI
FileSelectPopup -180 error
I'm using the fl8808 VISA driver in a CVI project.  Works great.  But I just discovered that it seems to be interfering with the CVI dialog function FileSelectPopup.  I get the -180 error code and the dialog doesn't pop at all.
I found this and that forum discussions.  They discuss forcing the thread type to COINIT_APARTMENTTHREADED, but that isn't working for me.
What I've found is that if I merely skip all the fl8808 functions, then the FileSelectPopup pops as expected.  My application isn't set up for multi-threaded at all (I'm assuming the fl8808 does).
(3,036 Views)
Any CVI engineers I can talk to about this?  It's kind of a show stopper for my client application.
(2,913 Views)
As a practical matter, you could try:
do
  status = FileSelectPopup(dir,"*.csv","*.csv","Data File",
                            VAL_OK_BUTTON,0,1,1,0,datafile);
while (status==-180);
I worked around the described problem with this trick.
(1,689 Views)
