LabWindows/CVI
General Protection Fault caused by table control with cvi 17 & 20
it seems to be that an already solved topic mentioned in the following link is appearing again:
Solved: Rif.: General Protection Error using Table Control - NI Community
In the attached cvi project you will find a table with one row and delete button in the first column of the row.
Clicking on that button yields sometimes to a general protection fault.
Sometimes it only appears after several cycles of adding & deleting rows.
Tested it with CVI 17 and 20.
Is there any idea or is it a known issue?
Best regards
Vitali Reitenbach
Message 1 of 1
(466 Views)
