LabWindows/CVI
FileSelectPopup always returns 0
CVI 2012, Win XP, Main Thread, on two different computers:
FileSelectPopup, with all the correct parameters passed, always returns 0, whether the operator selects a new file name, an existing file name and selects replace, or cancels.  FileSelectPopup should return a 1 or a 2 for the the first two cases, and 0 only for the cancel.  For new or existing file name, even though it returns 0, it returns a good path string.
This seems like some kind of new behaviour.  This chunk of code has worked properly before, looking for a 1 or 2, and worked in several different apps.
Any idea what is going on?
(4,824 Views)
Are you using a watch expression and stepping through your code to see the value be returned as zero? It is possible the value is being overwritten to zero elsewhere in the code that would make it seem like it eliciting this behavior.
Ian M.
(4,800 Views)
I stepped through the code -- that's how I found out it returns 0 always.
I worked around this by nulling the path string, and looking at the first character after return, even when the call returns 0.
err is local to this function:
   if ( err = FileSelectPopup (SupportDirName, SensorParamsFilename, ".txt",
              "Save Coefficients to File...", VAL_SAVE_BUTTON,
            1, 1, 1, 0, SnsrParamsFilePath) IS_LESS_THAN 0)
    sprintf(tempString, "FileSelectPopup Error:  %s\n", GetUILErrorString(err) );
    SysLogEntry(tempString);
    break;
   SysLogEntry("Save Params File: FileSelectPopup return value %i\n", err);
(4,786 Views)
The error is a result of setting err and then comparing it from within the if statement. If you first set err = FileSelectPopup then check if(err < 0) then you should see err will be nonzero. In my quick test I was able to recreate your issue but if you change the code as I mentioned it will work correctly.
Ian M.
(4,762 Views)
Seems pretty standard to embed a function call with return value inside a conditional.  I don't think I've seen an issue like this before.  But if you've recreated this, I'll take your word for it.  I suppose adding parens around the function call, so it is evaluated first, would solve it too.
 if ( ( err = FileSelectPopup (SupportDirName, SensorParamsFilename, ".txt",
            1, 1, 1, 0, SnsrParamsFilePath) ) IS_LESS_THAN 0)
Thanks for your help...
(4,750 Views)
The precedence of the less-than operator is higher than that of the assignment operator. This is why you must always include the parentheses, otherwise you're assigning the boolean result of the less-than comparison to your variable, not the result of the function call.
(4,732 Views)
Or possibly insert 2 calls in the if clause?
 if (err = FileSelectPopup (SupportDirName, SensorParamsFilename, ".txt", "Save Coefficients to File...", VAL_SAVE_BUTTON, 1, 1, 1, 0, SnsrParamsFilePath), err IS_LESS_THAN 0) {
(4,719 Views)
