LabWindows/CVI
RS 232 STRIP CHART
Hi dear,
please help me for this. I Have one  project with lab windows,but iam totally new in labwindows, I want to make stripchart plotting from rs232 I am getting 0 byte and 1 byte continuously from rs232 with rs 232 protocol , and I want to plot strip chart using labwindows please help me. pls send me code and UI  if you have any thing. my email id basithnv@yahoo.com
regards,
basith
(3,527 Views)
LabWindows/CVI comes with many examples, including serial communication and plotting on stripcharts. Why don't you start with looking at those examples (e.g. serial.cws)? Analyzing this code should help getting you started.
(3,520 Views)
I second Wolfgang answer: starting from examples is a good starting point.
Before of this, you should clarify better your requirements: "rs232 protocol" means nothing in this respect! RS232 standard simply defines the communication channel, but says anything on the meaning of messages that flow on this channel. How to interpret bytes received from an external instrument must be described in that instrument documentation which you should have and read carefully.
(3,514 Views)
