I'm trying to create a "timed" version of FileSelectPopup, which will offer a file-name to the user, and if there is no response after a short time period (10 seconds or so), the FileSelectPopup returns with the offered file-name. Since many of our tests run overnight, unattended, this would be a great way to place test data into different file locations in the absence of user-intervention... Yet, if the test is running in attended-mode, the user can place their own filename/location inside the popup as they normally would.
I figured that one easy way to do this was to use the FakeKeystroke () CVI library function inside a separate thread fired off just before the FakeKeystroke () function
(using the "Enter" key to dismiss the popup) that does the key-press while the modal dialog box is open. I'm finding that this doesn't work for this particular modal dialog box.
Another tactic I tried is the Windows SDK function "keybd_event". but again FileSelectPopup does not respond.
Right now I am about to build my own FileSelectPopup using the Windows "GetOpenFileName" function. Seems to me this is overkill, though...
So tell me, what do you think I'm doing wrong?
Thanks for any help from anybody...
DAB
To whom it may concern: My alias is also my nickname, I've had it since I was a (very) skinny basketball-playing teen. OK, so I've got a 38 inch waist now, but my hometown friends haven't shaken that appellation for me. I trust that you will someday be OK with that alias, as I have been with that nickname.
