FileSelectPopup function in LabWondows cvi to display the files as icons
Does anyone know hoe to default the FileSelectPopup in LabWindows CVI to display the files as icons?
Message 1 of 8
(4,538 Views)
Accepted by cjp1
to my knowledge the FileSelectPopup in CVI is inherited from Windows explorer, including the explorer settings
Message 2 of 8
(4,536 Views)
I set windows for display as icon and set under folder options, apply to all folders and under windows it works.
How ever the FileSelectPopup function still displays them in details view.
Message 3 of 8
(4,520 Views)
You can right click on the files list in the file dialog and select "View >> Small Icons" or whatever you want. This setting should persist in the file dialog even after closing the dialog.
Kevin B.
Message 4 of 8
(4,506 Views)
I tried the right click view-Icons and changed it to Icons. Closed the dialog box went back in and its back to details.!
Message 5 of 8
(4,500 Views)
What OS are you using?
Kevin B.
Message 6 of 8
(4,491 Views)
I running windows XP and have LabWindows CVI, 2009
Message 7 of 8
(4,468 Views)
I took a look at this on XP and you're right, the View settings aren't retained. However this is actually an issue with the operating system and not CVI. If you attempt this in Notepad you'll see the same behavior. In Windows 7 (probably Vista too but I didn't test it) this has actually been fixed and the View settings are retained in the Windows File Open dialogs (which is what FileSelectPopup launches internally).
Kevin B.
Message 8 of 8
(4,442 Views)
