LabWindows/CVI
FileToArray or readline to read a file and show the information in a textbox
I used the last few days to improve my C skills. Now I understand the benefits of structures. I read the file no longer only in an array. I started using fread, to save the file  into a structure and divide the data into logical components. In this way I can handle the structural logic then saved a lot better on. By using the structures of the source code is much easier and shorter. Previously I had too many variable names which already have me totally confused.
To deal with hexadecimal numbers, I had completely misunderstood. Now I know that it is only a matter of output. The presentation in tables is still under construction. By saving in a structures have not be all too difficult.
I thank you very much for the nice and competent help.
Message 11 of 13
(1,239 Views)
You're welcome! Smiley Happy
Feel free to ask again if you have any further doubt.
If you want some hint on using tables I suggest you to start a new thread as that argument is notably different from the one of this discussion.
Message 12 of 13
(1,236 Views)
All new C-learners I have been dealing with (interns, new engineers, etc..) tend to think hexadecimal as a separate data type, and they think an integer must be converted to hex in order to perform correct arithmetic operations.
Well, hexadecimal is just a representation as you already figured out.
This looks like a default learning curve for our minds on this subject 😉
S. Eren BALCI
IMESTEK
Message 13 of 13
(1,223 Views)
