LabWindows/CVI
Finding "USB to RS232" resources list
I'm wondering how to get the "USB to RS232" device name, description and serial number, as NiMAX is able to do (please see the attached image NiMAX-USB-232.jpg).
Using the viFindRsrc function (as in FindRsrc_CVI.cws example) I get the resource name only: "ASRLxx::INSTR" (viFindRsrc.jpg attachment).
Thank you for any suggestion.
Sergio
Message 1 of 13
(6,751 Views)
thanks fot the images, the problem seems ot be a missing driver like NI-SERIAL. What is the device that you use?
Best Regards
Mario
Message 2 of 13
(6,681 Views)
HI Mario,
I have NISERIAL installed, the device is NI USB-232/4 and everything is working ok.
My question is, how can I get its name and description as NIMAX does?
I'd like to develop a program that, looking at the VISA resources present in my computer, is able to find the resource name and description in addition to the information that viFindRsrc gives me (i.e. ASRL14::INSTR).
In other words, "ASRL14::INSTR" is not what I'm looking for, the information I'd like having is: NI USB-232/4 Interface "RS-232 SN:012EA3E9".
Do you have any idea about which CVI function I'd have to call and with which parameters?
Thank you and best regards
Sergio
Message 3 of 13
(6,679 Views)
http://digital.ni.com/public.nsf/allkb/8532AFF2C7E14F5E86256FEA003E202F  may be useul
Message 4 of 13
(6,664 Views)
THe link provided gives me an error:
HTTP Web Server: Lotus Notes Exception - Entry not found in index
Message 5 of 13
(6,657 Views)
fixed link http://digital.ni.com/public.nsf/allkb/8532AFF2C7E14F5E86256FEA003E202F
Message 6 of 13
(6,653 Views)
Hi nyc,
unfortunately the link you provided and the related links, are all proposing solutions for LabView, while I was looking for a LabWindows CVI solution.
Thank you anyhow!
Best regards
Sergio
Message 7 of 13
(6,645 Views)
Hi, this is just a temptative suggestion as I have not used these functions before. I am now starting a project with some cDAQ chassis and while searching for a way to inform the user of the installed modules I came across NI SystemConfiguration utility. This tool provides an instrument driver (NISysCfg.fp) located in shared\cvi\bin folder.
I see in the function help that you can set a filter so that it addresses all hardware that provides serial bus type: this way you could get a list of resources and possibly find there what you are looking for.
I cannot test in your situation since I haven't your hardware and I have not yet started to code my application, but I tought this idea could worth a try.
Message 8 of 13
(6,636 Views)
I have just found this example that uses NI ModInst in CVI to obtain informations on hardware. Unfortunately it refers to resources I have not installed in my system (specifically the library located in Program Files (x86)\IVI Foundation\IVI folder): if you happen to have this library installed then this example can be of help. You can pair this example project with the informations in the document provided by nyc to get what you want.
Message 9 of 13
(6,633 Views)
Hi Roberto,
thanks, this could be an interesting opportunity to fix my problem. I'll investigate this solution asap.
Best regards
Sergio
Message 10 of 13
(6,625 Views)
